Enables the removal of private autonomous system (AS) numbers from the AS_Path attribute of outbound updates.
peer-group-name | Specifies a peer group. |
Disabled.
This command applies to the current VR or VRF context.
The following command enables the BGP peer group outer from removing private AS numbers:
enable bgp peer-group outer remove-private-AS-numbers
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
